Posted by J.J. from Afton on May 14, 2009 at 19:40:58 from (66.41.82.17):
In Reply to: Re: farmall 460 pto posted by jon thompson on May 14, 2009 at 09:54:49:
Like Mark W said there are no snap rings or anything holding the shafts or couplers together it all just slides in and is held in by the four bolts on the outside. It does not always pull right out as it is a rather tight fit. It helsp to spin it back and forth slightly and you also have to keep it near perfectly level or it will not pull out easy at all, also like Mark said be ready it is heavy, Id say around 70 pounds at least. Also just remember which way the shaft couplers go should one or both happen to come out or if you remove them.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
