Re: Mystery Starter Cranking
Posted by SDE on May 15, 2009 at 09:57:34 from (72.160.219.199):
In Reply to: Mystery Starter Cranking posted by John T on May 15, 2009 at 05:27:49:
My 400 did that too. I believe that the switch had gotten wet and had shorted out. I am uncomfortable about leaving it outside after that. I will cover the dash with something if it is going to stay outside. I did replace that switch and it has not happened again.
SDE
Unanimous, don't you thimk?
