Re: Electric fan setup for a C International
Posted by Bob M on May 15, 2009 at 10:19:33 from (151.190.254.108):
In Reply to: Electric fan setup for a C International posted by Billybob-Ia. on May 15, 2009 at 08:36:36:
Are you having problems with the engine overheating?
If so, and if you are running the stock belt-driven fan, an electric fan will gain you nothing....except perhaps a little quicker warmup if you control the fan with a thermal coolant switch.
Reason: The stock fan can move more air at governed RPM than any electric fan you can make fit. Also unless you install a high-output alternator an electric fan will likely consume more amps than the alternator can provide at lower RPMs (= a dead battery if you don't run at full RPM!).
So I’d forget about installing an electric fan. Rather if the tractor is running hot the problem’s a partially clogged cooling system. Get the radiator clean inside and out. You'll find the engine will then cool just fine with the belt-drive fan!
