Re: Anyone ever had a generator converted to 12v?
Posted by Owen Aaland on March 11, 2009 at 20:07:12 from (65.165.246.54):
In Reply to: Anyone ever had a generator converted to 12v? posted by Janicholson on March 11, 2009 at 18:10:36:
Janicholson said: (quoted from post at 18:10:36 03/11/09) All 460 and above Farmalls and Utilities (and many older Farmalls (even letter series Diesels) had generators that were 12volt. Until IH started using alternators in the later years, they were 12v. they all look the same as the 6v generator. Identical in every detail. There were two different shaft lengths (if memory serves) and that can be made to work with the correct pulley. I would look to Ebay, or Some of the salvage yards, or put a want ad in the YT ads to the left. This is straight forward, and not a hard part to find. JimN
You need the long shaft to be able to use the adjustable pulley. 12 volt generators with with the long shaft were used for the MD and the 400 or 450 when the change was made from six volt to 12. The 460/560 and newer all used the shorter shaft.
