Re: The problems with my 48 cub
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Phil Auten (TX) on April 11, 2000 at 05:20:53 from (206.175.72.226):
In Reply to: The problems with my 48 cub posted by Mike Shoemaker on April 10, 2000 at 16:24:07:
Mike,
I had a similar problem with my Cub. Stalled it in the pasture and it wouldn't start. It would fire once in a while and kick out the starter bendix, so I was pretty sure I had spark. I pulled off the fuel line to check the gas flow and had very little (it should look like a garden hose with the water turned all the way on). Looked up at the sediment bowl, and it was BLACK inside. After draining and flushing the tank, I installed a fuel filter in the line to catch any further rust until I can cure the problem by sealing the tank. After a good cleaning of the carb, she runs like a Swiss watch again.
Phil
Post A Followup
: Re: Re: The problems with my 48 cub
