Hi, there is an inspection plate than can be removed on bottom of bell housing to look at the clutch. The transmission is driven by the inner shaft and the outer shaft is the PTO shaft. The PTO shaft is driven by splines on pressure plate. The PTO shaft also drives the hydraulics. Take the cover off the top of the transmission (between hydraulic housing and dash) and check that transmission shift control rod is working properly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
