Re: 350 engine in an H
Posted by RustyR on May 16, 2009 at 09:07:45 from (216.248.88.26):
In Reply to: 350 engine in an H posted by Justin Schiferl on May 15, 2009 at 21:52:21:
I'd think that 350u engine would be worth quite a bit more than than an H engine, and the tractor would be messed up afterwards as an antique. I've got a cheap H core engine if you're interested.
