Re: Grease fittings
Posted by Hugh MacKay on May 16, 2009 at 13:15:49 from (209.226.247.121):
In Reply to: Grease fittings posted by Roy Ward on May 16, 2009 at 10:17:25:
Roy: The manual actually calls for grease every 500 hours of operation or every 6 months. It calls for several strokes of the gun.
The one on the distributor shaft has a hole on the back side opposite the fitting. On that one when you see grease coming out that hole, you have enough. That one will put grease in the distributor if you go too much.
The fitting on the distributor drive gear housing can put grease in the timing gears and on to the crankcase if too much is used.
Harold is right, if you have yahoo's greasing, best to stick with plugs. If you alone, choose your method.
