Posted by GordoSD on May 16, 2009 at 16:11:11 from (66.115.200.140):
In Reply to: Re: Planting time posted by Rootsy on May 16, 2009 at 14:50:13:
I put 150 lbs of urea fertizer in each of those pesticide hoppers. Have both valves almost wide open. It helps hold the planter down, for min til, and "strip fertilzes" at the rate of about 60 lbs per acre, which would probably be 100 lbs broadcast.(36 inch rows) I just do food plots for wildlife so 80 bu corn is adequate. Plots are either 6 acres or 2.5 acres. Seven of them. You can't get those hoppers clean enough when you are done though. And store them INSIDE when not in use.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
