Re: Farmall 300 Power Steering
Posted by pete 23 on May 16, 2009 at 18:59:48 from (173.87.14.132):
In Reply to: Farmall 300 Power Steering posted by L. Dee Oliphant on May 16, 2009 at 14:59:19:
I am going to assume you put a complete factory style power steering unit with valve assembly etc. Like Slater said, did you put the plug in behind hydraulic valve on steering post, if so your problem is in flow divider, a new spool may take care of your problem or you may need a rebuilt valve assembly as has been discussed on this forum different times.
