I agree with Jimbos good assessment. Regardless if theres an extermely high poor/resistive/corroded connection somewhere in the voltage supply circuit (from hot ungrounded battery post) a good voltmeter (an "ideal" one has infinite resistance) will read near full battery voltage out on the end of the supply WHEN THERES NO LOAD ATTACHED.
HOWEVER if you place a load such as lights on that bad supply circuit then theres a current path to ground and current throught that high resistive poor corroded connection causes an IR voltage drop so the lights arent left with much.......However if theres a high resistance short or load the current should be limited (E/R) and the batteries voltage shouldnt drop much... Its when you have a low resistance high current draw the batetry voltage can drop as its NOT an ideal unlimited energy supply.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
