Re: 1951 Farmall Model-H Transmission fill plug size/removal
Posted by Rich in WI on May 17, 2009 at 09:40:59 from (72.69.148.47):
In Reply to: 1951 Farmall Model-H Transmission fill plug size/removal posted by Ron Olsberg on May 16, 2009 at 09:45:08:
Square stock with a wrench should work. I didnt have any stock that fit so I took a scrap of bed frame and welded it into a square of the correct size so it fit the plug. Then I welded that to a large nut I scavenged from work. I welded the inside solid but Im not sure it was needed as the plug came out easy. A little red paint and it looks good.
