pto shaft loose
Posted by Bill Teeters on May 17, 2009 at 15:41:50 from (67.77.224.2):
My super c pto shaft is leaking and loose. I took the pto off the tractor and the shaft is just flopping around. I need to pull the gear with a puller, I think. I can see some of the casting has broken and it is behind the gear. Is the pto ruined or will a new seal hold the oil and shaft. The tractor is used for grass cutting and my son took the over running off and I did not notice it. Where can I get a pto if needed? Should the bearings all be changed?
