Re: rear axle clamp bolts farmall H
Posted by mattofvinings on May 17, 2009 at 15:57:07 from (67.142.161.31):
In Reply to: rear axle clamp bolts farmall H posted by narrowfarm on May 17, 2009 at 12:01:48:
My thoughts are that Grade 5 is fine for this application.
I would use a little anti-seize on the reinstallation if it were me.
