Posted by J.J. from Afton on May 17, 2009 at 22:12:17 from (66.41.82.17):
In Reply to: 660 questions posted by bornred on May 16, 2009 at 15:37:25:
Nothing to pay more attention to than most older tractors like that. Just check for play in front axle see if all gears wrok, T/A if it has one and check for play in the steering gears, etc. Only difference in engine is early 282s had loose fitting sleeves, later ones had tighter fitting sleeves, which really doesnt make a difference unless your gonna be rebuilding it. Horsepower is all about if its still at factory settings or not, Id guess that 80% or more have been tweaked over time. Only other difference in early and late is the transmission recall but than there would be a delta or triangle symbol stamped in the name plate.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
