Yes you could post pics but i still would get a manual very helpful when mounting and setting for operation. Yes there has to be a round bar that goes from fender to fender and some stuff mounting on that bar so the beam can hook to the bar. Then there is a heavy u-shaped piece with some more brackets that bolt to the front atra of the tractor its probably 2ft wide and heavy found with the ends being small. The lever that mounts to the platform by the fender is for lifting other lever bolts to the bell housing by the filter and that one controls the dept of the furrow. There is realy a bunck of parts not fastened to the levers as the lift lever just has a rod going under the seat to the lift assy that goes from fender to fender it is spring loaded.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
