Re: SuperH Heads
Posted by pete 23 on May 18, 2009 at 16:44:02 from (173.87.14.132):
In Reply to: SuperH Heads posted by SuperHank on May 18, 2009 at 13:54:56:
There is a slight vacuum on this tube as it leads to the inlet pipe on air cleaner and as an engine will normally have more blow by than the amount of air passing through the tube you still need another vent for crankcase. Breather on side has a filter element in it also (chore boy) to keep the dirt out in case there would be a reverse flow. When the 460 and 560 came out they also had a vent tube to air cleaner from valve cover, but soon learned it just lead to more build up inside air cleaner inlet pipe and took it off and plugged hole at air cleaner and valve cover.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
