Re: Front rims on Farmall M
Posted by pete 23 on May 18, 2009 at 16:58:41 from (173.87.14.132):
In Reply to: Front rims on Farmall M posted by twedt on May 18, 2009 at 09:10:55:
Definetely use a grade 8 fine threaded bolt, I like to use a hardened steel washer, never a plain old flat washer, and you can use a lock washer if you like, however, I find that a lot of the lock washers you get now days are not very good quality. If the rim doesn't fit the hub good you will never keep it tight. I have seen some rather crude shims on outer diameter of hub between rim that have actually worked.
