Re: Farmall A PTO question
Posted by Mike Burns on May 18, 2009 at 17:06:03 from (74.5.56.57):
In Reply to: Re: Farmall A PTO question posted by leroy in ne on May 18, 2009 at 15:12:24:
Thanks for the reply. Mine was originally a rear mount Woods mower (RM59) that was converted to a belly mower by using just the deck, pulleys, and spindles. I need them to spin faster but did not know what rate the belt pulley shaft spun and now seem to have a consensus that it is 1147 rpm. Now I just need to revise my configuration and should be all set. I appreciate your quick response. The key was finding out that the belt pulley shaft is twice as fast. Thanks again!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
