Re: Front rims on Farmall M
Posted by D Slater on May 18, 2009 at 18:01:49 from (71.164.38.97):
In Reply to: Front rims on Farmall M posted by twedt on May 18, 2009 at 09:10:55:
From some of your posts It seems you may have the clamp type rims and wheels. They only use a 1/2 inch diameter bolt and the clamps are thin compared to ones used on the rear.
With a narrow front you could use the lower bolster, wheels and rims from a 560 or some other later farmalls with rims like you want.
You could also go with the loop style wheel and rims that use 5/8 diameter bolts. If so get wheels that the cast # on wheels ends in DB. They are thicker where bolt goes through and made to have a tighter fit with the rim.
