Re: Front rims on Farmall M
Posted by Rootsy on May 18, 2009 at 18:53:46 from (74.204.103.55):
In Reply to: Front rims on Farmall M posted by Twedter on May 18, 2009 at 12:46:09:
If I am reading your post correctly.. your rim pocket won't keep the bolt from turning.. so you cover the pocket with a washer.. then insert the bolt. this holds the bolt out so you can get a wrench on it while you tighten it. Am I correct? If so... Then you MUST get rid of that washer and get the bolt head seated against the hub. I wouldn't even bother trying to put a nut or anything under it to build it out.
