Pete, Thanks for the info. The T/A works good both ways, shifts pretty firm under a load. When I bled the right side brake last night I had a hose stuck into a pint bottle with some oil in it. With the tractor running and the pedal pressed down I opened the bleeder and it pushed out a tbl spoon max and quit. It didn't keep running as you indicated as long as the pedal was pressed. I took the pressure line off the valve (the one just below the Rt and Lft lines) and removed the fitting thinking the fitting might be the orfice. Didn't clean oil out of the body. Getting too dark out. Tommorow I'll clean it out and then look for the orfice? Is the orfice removable? What size of hole is the orfice. Thanks Dan
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
