Re: Plowing with a H?
Posted by rustyfarmall on May 19, 2009 at 06:15:39 from (209.152.78.140):
In Reply to: Plowing with a H? posted by Hugh MacKay on May 18, 2009 at 16:09:58:
Hugh MacKay said: (quoted from post at 16:09:58 05/18/09) Rusty: I've plowed many thousands of acres with H, 300 and 560, always used the swinging drawbar with a side hill hitch. I along with thousands of farmers wouldn't be without those two options, trailer plowing.
In the days of the H and 300 it was a notched lever for changing swinging drawbar side shift adjustment. By the time 560 and 4 bottom plows came along, we were using hydraulic cylinder for swinging drawbar side shift.
You're up in Canada. I am down here in Iowa. Apparently we do things differently. I've never seen a side hill hitch, or the need for a side shift hitch. If the tractor had a swinging drawbar, it was moved over to the side, out of the way, and the plow clevis was attached directly to the horseshoe, right in the center. Any adjustments needed to get the plow to trail correctly were made to the hitch on the plow.
