Posted by old on May 19, 2009 at 08:29:39 from (4.245.4.169):
In Reply to: Re: Farmall B Tires posted by Dick W. Pirkey, Jr. on May 19, 2009 at 08:05:57:
When you drain them add a bit more air then you would if your using it. Say around 25 psi, Then pull the core out and hook a hose like a piece of fuel line to it so as to keep the fluid away from the rim. Also that way you can direct the fluid where you want. Then when drained you just air them back up to the 10-12 psi that you would use normally
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
