Orfice is screwed into valve under the inlet fitting, is removable, I can't give you the exact size , only allows l gal per min so not very large, like maybe 1/16 but at any rate should not have to change size just make sure it is open. There is also a nylon check valve on the other end of that line at the mcv which may fail and block the flow to brake valve.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
