As long as the pressure relief valve is opening, it will only affect the steering. Its purpose is to limit the maximum pressure to the steering. The steering system gets priority on the MCV pump flow but unless the steering is held against the stops, the flow bypasses the relief valve and pressure is controlled by the regulator valve in the MCV assembly. Excess flow from the regulator valve is routed to the TA lube and again regulated by the lube pressure regulator valve.
Since your problem is not constant you may want to check to see if the orifice is loose in the MCV valve. It is accessed through the port in the rear of the MCV that has a 5/8 inch hex plug. An orifice that is out of place can cause the flow to vary in the MCV circuits.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
