Well the right way to do it is to make a puller tool of sorts that threads in the end of the crank and pull the flywheel onto the crankshaft. The way I did it most people advise against, as I used the holes that were tapped in the block and used various length bolts and heavy washers and pulled the flywheel on by tightning the bots slowly and in order. Challenge is to line up the notch for the pin. Again most people advise against this way as it puts a large lateral force on the bearings and housings holding the crankshaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
