Re: crank case oil contamination
Posted by Janicholson on May 19, 2009 at 17:19:16 from (66.173.50.20):
In Reply to: crank case oil contamination posted by Carl Naylor on May 19, 2009 at 03:52:13:
You are correct. Seal on the input shaft is probably bad. Set the engine up on #1 TDC compression before taking things apart. Mark the distributor location to retain timing. JimN
