There should be a safety wire or cotter pin in the threads to keep the adjuster from backing out. Remove that, then use a tie rod adjusting socket (big screw driver) to loosen the adjuster. The ball then slides to a larger area of the tie rod, and comes out. Look for ovaling of the ball, and wear of the pucks that push on the ball. If oval more than .005 or so, welding it up, and turning it round will be needed. If adjusted tighter on an oval ball, the ball will bind in the pucks, and possibly break off. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
