Re: Non Detergent oil
Posted by Mark on May 20, 2009 at 06:46:00 from (75.90.232.158):
In Reply to: Non Detergent oil posted by ChrisN1279 on May 19, 2009 at 18:57:37:
You should only use Farmall Brand motor oil, made in the IHC refinery and specifically marked model M motor oil. It comes in 2 types and on the top of the can...it will be plainly marked 'SUMMER' or 'WINTER'.
IE., Model M motor oil....SUMMER
Summer motor oil will make your engine run too hot in the winter and vice-versa, your engine will stay cold in the summer if you use winter oil.
Never ever use JD oil in your Farmall tractor, it will only run on 2 cylinders if you do.
Never ever run Ford motor oil in your Farmall or it will cease to run altogether.
Oh yes, I forgot to add; not any Farmall oil will work in your M, either!
Farmall A motor oil will make your M lean to one side..the left.
Farmall H motor oil will cut your horsepower.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
