Detergent oil does not really clean, it just keeps the solids in suspension longer and that feature tends to keep the engine cleaner.
That being said, I have switched many old tractors over to detergent oil and have never ever caused a problem with using it. I started doing this in the late sixties when you could still buy them that had never seen detergent oil.
The tractor is designed to last 50 years with an inferior oil, who knows how long they will last with modern oil? The engine can not tell if you put multi weight oil in it. It only sees 40 wt when it is hot and 10 wt when it is cold if you use 10w40. I use 20w50 because 50 wt is not too heavy once it gets hot and on some worn tractors it helps maintain oil pressure.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
