Posted by ScottyHOMEy on May 20, 2009 at 08:01:17 from (70.105.242.219):
In Reply to: 48 Cub posted by sammy in kansas on May 20, 2009 at 07:03:21:
Others can tell you for sure whether it takes a pressure cap or not.
What I'll add is that if you filled the radiator to the neck in preparation for running the tractor you should expect some overflow. It can be worse at first if you have any airpockets anywhere in the cooling system, as the air will expand more than the coolant as it warms and force coolant out. Can't hurt if you haven't already to run your Cub up a little bit of an incline to get any big bubbles up to the front of the motor and vented out the radiator.
Point is that the coolant will expand when heated and if you start with it absolutely full you will lose some. Perfectly acceptable as long as it settles down and finds its own level and stays there. That will usually be an inch or two below the bottom of the filler neck when cold.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
