Posted by Bigdog on May 20, 2009 at 08:56:54 from (71.64.18.18):
In Reply to: 48 Cub posted by sammy in kansas on May 20, 2009 at 07:03:21:
A non-pressure cap is correct. The thermo-siphon system operates on temperature differential to circulate the water. There is a lot of water expansion with that system. It will spit out excess fluid until it reaches it's best operating level. As long as the tops of the core tubes are still covered when the system is cool you have plenty of fluid. The typical operating level is 1 1/2" or slightly more below the fill neck when cold. The water will expand to fill the space when hot. If you fill to the bottom of the neck when cold it will spit out lots of fluid for a while. I'd operate it and let it spit out the excess keeping an eye on the level for a while. Most likely it will spit out the excess and settle down to a level that just covers the core when cold. A pressure cap will not affect this action but with an old system designed to operate with no pressure you may be asking for un-necessary pressure against old gasket surfaces.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
