Re: M Engine Kit
Posted by Andy Martin on May 21, 2009 at 05:16:34 from (199.197.2.142):
In Reply to: M Engine Kit posted by Andy Motteberg on May 20, 2009 at 22:15:34:
Measure your sleeves when you tear it down, you may have big bore sleeves already.
If you measure carefully, you may find the existing sleeves and pistons are OK and all you need are rings.
Don't order parts until you find out what you need. If rings are all you need they are very reasonable. It can be amazing what a valve job can do to an engine. Have you checked compression to determine whether you have ring or valve leakage?
