can't kill f-4 magneto
Posted by chuck kaufman on May 21, 2009 at 08:18:00 from (69.1.112.218):
I've got a F-4 mag on myO14 that I'am unable to kill.I get real good srark in all postions of the retard/advance lever.It's my understanding when the lever is fully retarded the mag should be dead .I took the lever housung off and can see the little pin I assume grounds the points.I took my vom meter to check continuity between the body of the mag and the points.I tried all different combinations to put the probes between.I get continuity everywhere no breaks.What next? Thanks Chuck K.
