You can probably get the copper tubing at Home Depot. Take a piece of the old tubing along so you get the correct size. It may be 1/4" od tubing. You can use compression fittings or double flare the tubing and use flare nuts on the tubing and change the exixting fittings to brass 45 degree flared fittings. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
