Re: Farmall 350 has black spark plugs
Posted by Red Mist on May 21, 2009 at 14:40:42 from (67.142.130.36):
In Reply to: Farmall 350 has black spark plugs posted by GordoSD on May 21, 2009 at 09:20:16:
GordoSD said: (quoted from post at 09:20:16 05/21/09) Have you changed the load adjustment? That idle screw only affects the mixture at idle. Are you gettin some black or brownish smoke when you pull the throttle open?
If you can't lean it out with the load screw then you will have to lower thr float setting. That is adjust so that the valve closes "sooner
(lower fuel level in bowl).
Gordo
I agree with Gordo; well worth trying.
mike
