Re: mounting an alternator onto an H
Posted by matt from WI on May 21, 2009 at 15:02:12 from (98.144.8.198):
In Reply to: mounting an alternator onto an H posted by Brad in WI on May 21, 2009 at 14:18:59:
Brad, I went thru two one wire alternators on my H and consistently had problems exciting the alternator to charge. I cured the problem by switching alternators and going with Bob M's three wire alternator set up. I havent looked back. I hope this may be a little advise to save some trouble in the future. The mouning bracket will be the same for both alternators. Matt
