240U hydraulics
Posted by internationalembalmer on May 21, 2009 at 15:38:40 from (70.197.47.154):
Hello,
Is there any way to bypass the factory controlls on a 240U. I would like to keep the tractor as original as possible but there is a recurring issue with the spool valve and safety block in my system. I recently replace the hydraulic pump and wouldn't you know it the rest of the system is used up as well. I have alredy replace and rebuilt everything I can and new control units are very pricy. I am not farminf or restoring but I do use this unit for Mowing and working my arena and also moving some round bales so the three point is a must. I don not however need the traction control or the automatic depth control that the facoty unit allows for. So with that said I would like to fix it as inexpensic=ve as possible but not loose historic value. Please any thoughts would be greatly appreciated. Thank You Jim
