Re: IH 666-Need Help!!
Posted by trulyred on May 21, 2009 at 18:08:43 from (216.252.3.187):
In Reply to: IH 666-Need Help!! posted by BobHnwOh on May 21, 2009 at 15:50:21:
The actuator has stuck open and is not returning. You will have to remove the brake assembly, take the three springs loose that hold the actuator together and clean up the area (ramps) where the 5 balls operate. Once your inside you can see what is wrong. Remove the outside cover, you"ll have to pry and work it off of the 2 dowels (maybe 1 dowel) then disconnect the ball nut adjuster and work the actuator from the pedal and out of the brake housing. If you end up replaceing the disks you will need more shims than you have. Note on the actuator which side is out, accidentally turning it over can cause a new set of problems.
