Re: ih 3616 with c-221 gas motor
Posted by Ed pap on May 21, 2009 at 21:23:22 from (74.33.246.97):
In Reply to: ih 3616 with c-221 gas motor posted by James Friery on May 21, 2009 at 15:34:29:
Hello James,
I think that is a dry sleeved motor. The best case would be a freeze plug under the valve cover is bad then a head gasket then a crack somewhere. I would pull the valve cover and fill the rad if nothing then I would pull the oil pan and look. you might have to pressurize the rad to find the leak.
Good Luck Ed
