Re: 300U with stiff clutch
Posted by Ed pap on May 21, 2009 at 21:32:12 from (74.33.246.97):
In Reply to: 300U with stiff clutch posted by SproutW on May 21, 2009 at 21:14:12:
Hello,
The 300 didn't have the best set up on the clutch pedal but it should wear you out, maybe you have to adjust the lincage. the TA works off the clutch you could be fighting the lincage if it is out of adjustment. I would sugest getting a manual to adjust the lincage correctly. I do alot of thoses clutches and TA's and I need the manual everytime. if the lincage is ok then it could be the pressure plate on your clutch.
Good Luck Ed
