Janicholson said: (quoted from post at 20:13:07 05/22/09) Both VRs may be bad. There are good new VRs on the market, they cost a bit more, but work well and longer. The field winding is grounded to make full output. Thus the F terminal on the Regulator leads to ground through the regulator frame. Testing it is a good idea. Keep us informed. JimN
The 2444 should have a 10DN series AC generator, better know an as alternator.
The regulator has internal connections to both battery voltage and ground. The field circuit of the alternator is internally grounded and needs voltage from the regulator applied to the F terminal to charge. Either grounding or applying battery voltage to the field circuit while the regulator is connected can fry the contacts in the regulator.
Poor or missing grounding at the regulator can lead to overcharging.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
