Posted by billde on May 22, 2009 at 20:53:39 from (72.26.89.156):
In Reply to: MOWING WITH A CUB posted by PRTZMAN55 on May 22, 2009 at 05:36:52:
PRTZMAN55 said: (quoted from post at 05:36:52 05/22/09) Morning All,
I need your help with a question about mowing with my IH cub.
Its a 67 with a IH mower driven by the power take off pulley. Does the pulley turn at the same rpm all the time ? My grass is getting high and the ground is starting to dry up so now is a good time to mow. In the shorter grass it does ok but it deeper grass it wants to bogg down. MY reaction is to throttle up but that make it go faster, if up press in the clutch it will stop.
If you were to run at lower engine rpm s will the mower still go as fast as it would at higher engine rmp . I guess my question is does the pto pulley run at the same rmp all the time ?
thanks for your replys
Harry
The PTO runs the same speed as the engine. If the engine speed is 700 RPM so is the PTO speed, engine 1800, PTO is 1800.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
