Re: ih 3616 with c-221 gas motor
Posted by James Friery on May 23, 2009 at 05:53:53 from (70.60.17.129):
In Reply to: Re: ih 3616 with c-221 gas motor posted by Ed pap on May 22, 2009 at 13:28:01:
Ok i took the exhaust manifold off because it had two holes in it, also found a bunch of crap in all of the ports....pulled the valve cover off and all looked good.....pulled the head off and found a bent push rod, and badly rusted cyclinders......i will look at the head gasket in a couple of days...i gotta work 3 12 hour shifts the next few days....thanx again for everyones help....i took pictures and will post them tonight.
