Re: 560 hydraulic pump
Posted by Armand Tatro on May 23, 2009 at 06:16:39 from (71.239.10.80):
In Reply to: 560 hydraulic pump posted by brian brooks on May 23, 2009 at 04:15:53:
Do you still have the old pump? Best advice I can give is to get some expert help and pull the pump and compare the pumps and part numbers. When I did my pump I took my pump assy.(two pumps attatched togather) to my case-IH dealer, both pumps were bad, and I got a new pump assy. and re-stalled. Was the power steering working before you swapped pumps? Is the power steering factory or after market? If after market it would have its own pump mounted externally and belt driven. Armand
