Re: smta no start
Posted by Janicholson on May 23, 2009 at 15:47:48 from (66.173.50.5):
In Reply to: Re: smta no start posted by paul smta on May 23, 2009 at 15:27:14:
Two ideas: I would use magnetic suppression wires They have a fiber core with real wire wrapped around the core. The wrapping kills the static, the wire conducts electricity really well. As good as solid wire. The second component is that there may be a faulty connection instead of wire issues.
(or the Petronix unit is getting intermittent. If the coil is hot, it can fail when hot and work when cold. A second coil ruled that out, but if the Petronix unit is failing in the on state, it will get the coli hot. Never leave the ignition on not running. it cooks the electronics in the Petronix. Good luck, JimN
