Re: 1941 H Farmall
Posted by Janicholson on May 23, 2009 at 16:33:20 from (66.173.50.5):
In Reply to: 1941 H Farmall posted by bodid1998 on May 23, 2009 at 07:10:24:
The consensus on this forum is that there are two sources. One is condensation. As the trans cools it breaths in (water vapor in the air condenses inside). because the tractors are not run hard all day any more they do not get hot enough to heat the water out)
The second (and pretty easily fixed) source is the shifter tower. I would put a Constant velocity boot over the lever, and clamp it to the shaft.
Select the boot that fits best. JimN
