Re: Farmall C compression problems
Posted by Roy Ward on May 23, 2009 at 18:56:53 from (66.82.9.56):
In Reply to: Farmall C compression problems posted by Joe Rhodes on May 23, 2009 at 18:41:33:
The cylinders with low compression have you tried putting about 2 table spoons of oil in the cylinders and then check the compression and see what you read. If the compression does not come come up you have valve problems. If the compression comes up the rings are your problem.
I have used this method on a lot of motors and have had good luck with it.
