I had lower compression on #1 (on a 140, 120 psi vs 150 psi on 2,3, & 4) until I reamed the plug hole threads (18mm) so the pressure gauge fitting could seat properly. If the compression is really that low combustion will be poor and the cylinders will probably get gummed up. I would ream the threads and use anti sieze on the plug/fitting threads.
My manual says set 0.014 in. on intake valves, and 0.020 on exhaust valves. I've heard others say set all at 0.014 in.? I use the manual settings and haven't had a problem. Isn't there more danger of burning exhaust valves if they are set at 0.014 in.?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
